BArnold
- Jun 23, 2018
- 2
- 10
I received the suspension system Monday evening, but had other things on my schedule. I installed it Wednesday evening but not without a couple of issues.
The instruction say to remove the seat slider mechanism and mount it on top of the suspension system. When I checked the clearance after removing the slider, there was no way to get the seat pressure sensor wire reconnected. So, back up a bit and re-mount the slider to the seat. The next issue was mounting holes on the suspension, so I had to drill two additional holes for it to fit onto the sliders. Then, I had to drill two additional holes in the seat panel on the mower to match the suspension system. Anyway, I got it mounted last night in time to do my regular mowing today. While it's not like going down the road in a luxury vehicle, the suspension did soften the bumps in my lawn somewhat. I've got it set pretty far to the "SOFT" side and will continue to play with the setting to see what works best.
Thanks again for the encouragement to take the plunge!
