54C DECK GAUGE WHEEL ARMS
snowman 62
I can't seem to find the right gauge wheel arm mine are 3/4 inch diameter the only ones the dealer has are 7/8 dia. any clue as to the part # i need? thanks
Mower model number and serial number will be needed for an answer.
deck Model # 54C serial # 1MO54CPAPFM100613
X 534 mower serial # 1MOX534ATFM100510
thank's
Does this help?
Have your local JD check the AM138220 shaft size. But note this mower's deck uses three different arms on the same deck at the same time.
