54 Raptor SD 935882 - idler arm
TRS
Hey guys. My idler arm on the drive belt seems to be quite wobbly in the vertical direction and is throwing belt on occasion. I replaced, reinforced all the hydro/frame mounts and this seems to be the last thing that could be causing the belt throw. I can get to the bushing after removing back tires but how do i replace the square carriage bolt? It seems to be under the engine and can't just slide it out. Any ideas?
Unless the carriage bolt is damage you don't need to remove it. But the engine has be loosen to get the bolt out.
Normally what needs replacing is spacer bushing, idler arm, and the washer.
