Fireman 123
- May 14, 2011
- 42
- 358
Buy a mechanics handbook from eBay. It's very useful if you're planning on keeping the old mowers going.
1 preset altitude needle 1/2 turn from seat
2 start and let warm for 3-5 min.
3 place speed control to low
4 slowly turn needle CCW until engine running smoothly
5 place control to high, if not running smoothly turn CCW 1/8 turns at time till smooth
6 shut-off and immediately try to restart, DO NOT PRIME, should start within a couple pulls at both
low and high settings, if not contitnue turning needle 1/8 turns CCW to obtain easy starting.
This is from manual, good luck, looks like everyone pretty much have it covered. Fuel+ Air+Combustion+Ignition=VROOOOOM.
Thanks, Hankthecrank. ..... Great to get such precise information. You mention an altitude needle. My carb doesn't have one. That confused me. Instead, it has an "adjustable fuel flow needle valve" on the top. Finally, I ferreted out information on the internet saying Lawn Boy made the model 5247 from 1978 - 1982. During that time, they used three different carbs on the F100 engine. The first two had the altitude adjustment screw. The third carb (mine) has the "adjustable fuel flow needle valve."
I'm going to fiddle with adjusting it as soon as it stops raining. ..... Got the feeling I may get lucky and "get 'er done." :laughing:
Maybe I'm missing the concept, but I can't imagine adjusting the carb while mowing at the same time. My arm isn't that long haha?
I'll look for one. ..... Sure wish I'd had one a few days ago. It would have made my Lawn Boy repair adventure a lot easier and less time consuming. I've learned a lot.
