500e to small gas tank
CurtOr
I have a 500e series with a hole chewed in the gas tank. The biggest issue I had with the engine was the gas tank was to small (.8gal). Is there a larger tank that will bolt right on?
dougand3
Need to post full engine model #. Eg: 09P707-1234-E1. Probably dot stamped into block.
Scrubcadet10
Moderator
Staff member
Either that, or i worked on a 300e that it was on sticker between the valve cover and air filter.
