MN-Welder
- Aug 20, 2020
- 1
- 2
Hello I’m currently working on a home built brush mower, to power it I bought a 17.5hp ohv Briggs engine. The problem is the carb just has a small piece of tubing to a fuel filter. For the gas tank I’m using a 6 gal marine tank gravity feed isn’t an option. I’ve looked into putting a Briggs pulse powered fuel pump but I haven’t found a fitting on it. I looked at the 540cc Briggs 19hp which was basically the same thing with an oil filter and a fuel pump. The pulse hose connected to the side of the engine but my 17.5 doesn’t have the connector. Is there a way I can add one to the engine or do I need to buy the 19 horse engine? I’ll post a picture I took of the 19’s pulse hose it seemed to be in a odd spot.
19hp Briggs
My 17.5 Briggs
19hp Briggs
My 17.5 Briggs
