5-6 hp Honda Gcv160 Horizontal
Etbrown44
Been a great motor. Drained tank end of last season. This season it starts fine but wants to backfire some through carb and blew air filter off. Runs well without air cleaner.
Suggestions.
Install new oem air filter, cost a little more but will work better then some really badly made aftermarket air filters. Some are made with thick hard paper and engine can't breath good.
Here's what AI suggests...
Of course! A backfire through the carburetor on a Honda GCV160 is a classic and frustrating problem. It's a distinct "pop" or "bang" from the air intake area, not the muffler.
This symptom almost always points to one of two main issues: a lean fuel mixture or a valve problem. Let's break down the causes, from most likely to least likely, and how to fix them.
⚠️ IMPORTANT SAFETY FIRST ⚠️​
  • Disconnect the spark plug wire before doing any work. This prevents the engine from accidentally starting.
  • Let the engine cool down completely.
  • Work in a well-ventilated area, away from any open flames or sparks. You'll be dealing with gasoline.
  • Wear safety glasses to protect your eyes.
The Most Common Causes and How to Fix Them​
Think of a backfire through the carb as an explosion happening at the wrong time in the wrong place. The engine's intake valve is open when it shouldn't be, allowing the combustion event to travel backward.
1. Lean Fuel Condition (The #1 Culprit)​
This is the most common cause, especially if the mower has been sitting for a few months with old fuel in it.
  • What it is: A "lean" mixture means there's too much air and not enough fuel getting into the cylinder. The mixture doesn't burn completely in the combustion chamber. When the intake valve opens, the hot, unburnt fuel gets sucked back into the intake tract and ignites from the heat, causing the "pop."
  • Common Causes:
    • Clogged Pilot Jet: Inside the carburetor is a tiny hole called the pilot jet (or idle jet). It's responsible for delivering fuel at low RPMs and idle. Ethanol in gasoline loves to clog this jet with varnish.
    • Clogged Fuel Passages: Other small passages in the carb can get blocked.
    • Vacuum Leak: A bad gasket between the carburetor and the engine, or a cracked fuel line, can let "unmetered" air in, leaning out the mixture.
    • Old/Stale Fuel: Gasoline goes bad in 30-60 days. It loses volatility and leaves behind gummy deposits.
  • The Fix: Clean the Carburetor Thoroughly
    • Simply spraying carb cleaner into the throat of the carb will not fix this. You must remove the carburetor from the engine.
    • Remove the carb (disconnect fuel line, throttle linkage, and unbolt it).
    • Disassemble it carefully, taking note of how all the springs and linkages go together (take a photo with your phone!).
    • Remove the float bowl. You'll see the float and the main jet in the center.
    • Remove the main jet and the pilot jet (the pilot jet is often a tiny, brass, hex-headed jet located deeper in the carb body).
    • Clean everything with a quality carburetor cleaner spray. Crucially, use a tiny wire (a single strand from a bread tie or a guitar string works well) to poke through the holes in the jets. Make sure you can see light through them.
    • Inspect the carb-to-engine gasket. If it's brittle, cracked, or damaged, replace it. A carb rebuild kit is cheap and highly recommended.
    • Reassemble and reinstall the carburetor.
2. Valve Issues (Very Common on Older GCV160s)​
This is the second most likely cause, especially on engines with several hundred hours of use.
  • What it is: The valves need to open and close at precise times. Over time, the valve clearance (the small gap between the rocker arm and the valve stem) can shrink to zero due to wear. When the clearance is too small, the intake valve can't fully close, creating a pathway for the combustion explosion to escape back through the carb.
  • The Fix: Adjust the Valve Clearance (Valve Lash.....
  • Common Causes:
Did you really type all of this?!
A. I. typed all of that.
Do forum guys think it sounds right or needs correction?
Honda does NOT make a horizontal GXV160 it is a GC, GS, or GX 160
This particular motor is a GX, and still interested to hear if this advice seems right!
Big difference between a GX and the GC/GCV listed in the OP.
And as previously said could be a lean run issue that is causing the backfire, or could be a sticky intake valve hanging up momentarily, or could even be something has occurred resulting in a partially sheared flywheel key.
