tom3
- Apr 9, 2018
- Threads
- 25
- 1,579
Series 11000 OHV horiz specs
ENGINE SPECIFICATIONS Armature Air Gap .010 - .014 in. (.25 - .36 mm) Crankshaft End Play .002 - .028 in. (.05 - .71 mm) Spark Plug Gap .030 in. (.76 mm) Valve Clearance – Intake .004 - .006 in. (.10 - .15 mm) Valve Clearance – Exhaust .009 - .011 in. (.23 - .28 mm)
FASTENER TORQUE SPECIFICATIONS TORQUE Air Cleaner Base / Backplate 40 lb-in. (5 Nm) Armature 30 lb-in. (3 Nm) Blower Housing 90 lb-in. (10 Nm) Bracket to Carburetor (Snow) 45 lb-in. (5 Nm) Carburetor Bowl Screw 90 lb-in. (10 Nm) Carburetor to Cylinder Head 85 lb-in. (10 Nm) Connecting Rod 100 lb-in. (11 Nm) Control Bracket 100 lb-in. (11 Nm) Control Panel Trim 40 lb-in. (5 Nm) Crankcase Cover 100 lb-in. (11 Nm) Cylinder Head 220 lb-in. (25 Nm) Cylinder Head Plate 100 lb-in. (11 Nm) Cylinder Shield 30 lb-in. (3 Nm) Exhaust Manifold / Adapter 180 lb-in. (20 Nm) Flywheel Nut 100 lb-ft. (135 Nm) Flywheel Fan 180 lb-in. (20 Nm) Flywheel Guard 30 lb-in. (3 Nm) Fuel Tank 85 lb-in. (10 Nm) Governor Lever Nut 45 lb-in. (5 Nm) Muffler 100 lb-in. (11 Nm) Muffler Support Bracket 45 lb-in. (5 Nm) Oil Drain Cap – Front (Snow) 130 lb-in. (15 Nm) Oil Drain Plug – Side 100 lb-in. (11 Nm) Oil Fill Tube 50 lb-in. (6 Nm) Rewind Starter 30 lb-in. (3 Nm) Rocker Arm Stud 100 lb-in. (11 Nm) Rocker Ball Set Screw or Nut 45 lb-in. (5 Nm) Spark Plug 180 lb-in. (20 Nm) Starter Cover 20 lb-in. (2 Nm) Starter Motor 140 lb-in. (16 Nm) Rocker Cover 55 lb-in. (6 Nm) Snow Hood 40 lb-in. (5 Nm) Snow Shield
REJECT DIMENSIONS STANDARD SIZE REJECT SIZE CYLINDER Main Bearing .876 in. (22.25 mm) .878 in. (22.30 mm) Camshaft Bearing .5008 in. (12.72 mm) .5040 in. (12.80 mm) Bore Diameter 2.688 in. (68.28 mm) 2.692 in. (68.38 mm) Bore Out-Of-Round N/A .0015 in. (.04 mm) CYLINDER HEAD Valve Guide .249 in. (6.32 mm) .267 in. (6.78 mm) Intake Valve Stem Diameter .247 in. (6.28 mm) .244 in. (6.20 mm) Exhaust Valve Stem Diameter .247 in. (6.28 mm) .244 in. (6.20 mm) CYLINDER COVER Main Bearing 1.063 in. (27.00 mm) 1.065 in. (27.05 mm) Camshaft Bearing .501 in. (12.72 mm) .504 in. (12.80 mm) CRANKSHAFT Crank Pin Journal 1.098 in. (27.89 mm) 1.097 in. (27.86 mm) Mag-Side Journal .874 in. (22.20 mm) .873 in. (22.17 mm) PTO-Side Journal 1.061 in. (26.96 mm) 1.060 in. (26.92 mm) CAMSHAFT Mag-Side Journal .499 in. (12.67 mm) .498 in. (12.65 mm) PTO-Side Journal .499 in. (12.67 mm) .498 in. (12.65 mm) Intake Lobes 1.112 in. (28.24 mm) 1.098 in. (27.29 mm) Exhaust Lobes 1.112 in. (28.24 mm) 1.098 in. (27.29 mm) CONNECTING ROD Crank Pin Bearing 1.100 in. (37.06 mm) 1.102 in. (27.99 mm) Piston Pin Bearing .6258 in. (15.89 mm) .6268 in. (15.92 mm) PISTON Piston Pin .6247 in. (15.86 mm) .6242 in. (15.85 mm) Piston Pin Bearing .6258 in. (15.89 mm) .6268 in. (15.92 mm) Ring End Gap (Top) .006-.010 in. (.15-.25 mm) .020 in. (.51 mm) Ring End Gap (Middle) .012-.020 in. (.30-.50 mm) .030 in. (.76 mm) Ring End Gap (Oil Control) .020-.025 in. (.50-.63 mm) .035 in. (.89 mm) Ring Land Clearance (Top) .002-.003 in. (.05-.08 mm) .004 in. (.10 mm) Ring Land Clearance (Middle) .002-.003 in. (.05-.08 mm) .004 in. (.10 mm) Ring Land Clearance (Oil Control) .002-.004 in. (.03-.07 mm) .005 in. (.12 mm)
