kippstakes
- Jun 1, 2016
- 3
- 4
I've been doing some work on my mower and cant seem to smooth out the idle. At low throttle the engine purrs, but when it's throttle up/set to high the idle is all over the place. I don't think it's the governor since I can hold the throttle valve open with a driver and it still goes up and down. The carbs are clean, the airbox is clean, it's getting a good spark and the compression is 90.
Any ideas?
Thank you
Any ideas?
Thank you
