Engine 48" tiger cub 24HP BS
fjamesfsilk
I just recently obtained this 24 Hp BS and it starts and go full throttle . Any comments
KennyV
Any comments
Sure: ....
WELCOME to LMF...
It sounds like the governor is disconnected, There is a spring at the carburetor that holds the throttle wide open... the Governor linkage pulls Against that spring to close the throttle.
You have either bent or binding linkage OR disconnected or not functioning governor...
Look over the linkage around the carb to see if anything is amiss... :smile:KennyV
fjamesfsilk
Ok pulled the carbs and discovered the butterfly has come off and don't see the screws. I am thinking about pulling head to see where screw went too. Engine runs but wide open no missing can pull lever between carb and governor and runs smooth , but as soon as i release it goes racing again. I am being told governor inside engine. Like to hear others opinons.
scott47429
sounds like you need to find the screws and put the butterfly back in the carb and it should be fine without the butterfly its like running wide open nothing to restrict the air and fuel flow
fjamesfsilk
Reconnected butterfly but did not find screw and it still runs wide open. When i move the governor by hand it runs great but as soon as i let it go its wide open again.
scott47429
is the governor connected to the throttle linkage maybe post some pics so we can see what your dealing with
KennyV
If there is anything left of the screw, it may be in the muffler...
Try adjusting the governor, here is a brief How to video clip from youtube, there are several...
Governor Ajustment Briggs V-twin - YouTube
The governor is always trying to over power the spring that holds the throttle open... if the governor is not adjusted correctly, it will not be able to pull against the spring.... :smile:KennyV
fjamesfsilk
Pulled head busted piston , best place for parts for this BS
