cpurvis
- Aug 25, 2015
- 2,256
Small block Chevy is (in my mind) the best V8 car engine ever made. It's astounding how close the designers got to "right " on the first try.
I thought maybe you'd go with a 340 to keep it in the family, so to speak.
My only experience with a Mack R-700 was a few days rental. It had the Maxi Dyne and a 5-speed. AMAZING torque rise. I owned a 3406B Cat and the Mack would out-pull it. I liked the looks of the B-61 Thermodyne but never got to drive one or a Triplex. I did drive a Ford dump truck with 5x4 which I would guess is somewhat similar. 20 'gears' but you don't use them all. Takes a few hours to find the right combinations then you're set. I used the back transmission as a clutch; find the gear you want in the main box, then find the right one in the rear. Slick as glass; no grinding. I liked the two sticks better than a Fuller RR.
Anyway, if I had the money I'd go ask if the owner wants that R-700 hauled off. It'd make a good parade or show truck.
