Snow blower 47- snowblower on a 2210 john deere
valkyrie1
Hi
how do I get the auger out of the snowblower??
the shaft that goes to the back of the blower do I have to pull the gear off it??
is there some form that I can go to see this thing is put together ??
thank you for your help mike.
You've got a big job on your hands. Yes, you do have to remove everything on the back of the blower. Also, remove the end cap bearings. The auger comes out as one unit, gearbox, auger, bearing collars and fan. Think of the letter T that the shafts form, as one unit.
valkyrie1
thank you for your help Rivets. I have a bolt sheard off on the back of the gear box.
Now that is a much cheaper and easier repair. $2.00 plus your labor. Glad you found that.
