450 e-series II broken rear handle
bitdemon
I loaned my chainsaw to a young bloke and he came back full of apologies about how a limb bounced and broke the rear handle. I've had a search for parts diagrams online without too much luck but it appears that the handle may be integral with the fuel tank assembly. Is the handle available separately?
If it's not available, I might have a bash at plastic welding the cracks, guessing it's thermoplastic. Anyone have any idea of what type of plastic it is?
The serial number is 2014 0200516 967 15 69-00.
Thanks.
Fuel tank is integral with the rear handle part number 525862104, subs to 537437906. And doesn't come with fuel lines, or any of the trigger throttle handle parts. so those will have to be removed and reinstalled on the new fuel tank assembly or replaced separately if broken
Good news it appears the tank is only $40 US
E series, will be pretty simple swap out if you've got a decent head on your shoulders
Looks like I'll be buying from the US... Just dropped into the local stealership and they wanted US$164 for just the 537437906 handle!!!
