I ordered the solenoid and hope to be" in business" next week. It seems to be the likely problem. TPH will be for a box grader, thanks for the tips
Status update: new solenoid installed and I changed the fluid and filter. Tested the old and new with current direct from the battery 12.4 tested. Neither one fired,clicked or anything. There was a spark as I touched the contacts. Black to ground and the other wire positive. Nothing. The unlined runs fine and the safety switches for seat and reverse interrupt jumpered. Both LED lights on. Test procedure #6 has no voltage. It is on per the schematic on the control module board and no voltage it’s a black wire and has tested continuity to ground. What is the page reference for the power circuit or where should I rest next? The procedure is confusing using the pdf manual thanks in advance
I stripped the plastic nut reinstalling it for a retest as I didn’t have it at the 45 degree angle. Could that have affected it firing? Hope I can but a new nut
