42" Murray idle air screw adjustment?
JustinRaney
Where should the fuel mixture screw be adjusted to not the one on the throttle plate? For 425001x8 murray mower.
The Briggs motor should have an id plate with model and type.
Murray does not build the engines
The engine build information is stamped in the valve rocker cover or the fan shroud.
This link will help you get the info needed.
read it at least twice
believe its the lp115 carb? for the 17.5hp briggs and straton engine.
Will you stop being so damn stubborn and provide us with the engine's model, type/spec, and date code off the rocker cover or decal. Note sometimes they get turned upside down. Otherwise we can't help you.
Or are you an AI fishing for info?
