arturowesley
Have a 42" raptor which does not have as much power on the right as the left side. I looked at several videos on how to check and change hydro oil but my raptor has no oil reservoir. How can I check if both sides are full?
Good advice. Yup, it's pretty common for Z mowers to pull to one side right out of the dealer. Many don't spend the time necessary to get them tracking perfectly. It takes more fiddling around than they have patience for it seems. My Exmarks have knobs for tracking adjustment. My Bobcat doesn't. It was pulling to one side when I took delivery so I had to hold back on the other side and couldn't reach max speed. I brought it right back to the dealer and they adjusted it while I waited. The mechanic thought he'd checked it but it was the other machine they sent out that day, not mine. I've fine tuned it a little since then. It's not exactly intuitive what to shorter and lengthen, at least not to me. It still doesn't go straight if you pull both sticks back all the way into full reverse. Sorry, I'm rambling, but yeah, sometimes it's just an adjustment issue. Definitely want to make sure it's adjusted properly before doing anything else.If you have no experience working on sealed hydro units, I would highly recommend leaving them alone! There are adjustments that can be made to the controls of a zero turn to change how the mower tracks when driving. This may be your issue. Google search "Hustler Raptor General Service Manual" and this should help. Look at the steering adjust and control lever stops. Good luck.
Mike
