4.75 Briggs will not stay running.
jfulton50
Took carb apart and cleaned with spray cleaner. Was afraid to put in bucket of carb cleaner. Replaced primer bulb. Cranked it up and it ran for a few seconds and if I bounced the mower up and down it would keep running but if I let it sit it would stop. Didn't know if there was a needle valve stuck possibly. Any suggestions?
Thanks,
John
mechanic mark
Post engine numbers from data plate, check spark plug & air filter for replacement, fresh gas in tank.
Viton seat swelled, not allowing enough fuel into the float bowl.
