350 Wiring
jagg2236
Can anyone tell me where the all wire's connect from the coil & off switch on my 350 Husqvarna chainsaw? I can't find a new harness either, the old harness is history! so the only option is making one. Any info would be appreciated.
Ring terminal under one of the coil mounting bolts to a flat female at the switch
Falt female on the switch to flat female on the coil kill wire some times a 1/8" wide one
Wires run along the outside of the plastic shroud , should have tabs to secure them
