345 liquid cooled starting issues
mrfred54
what to look for, this tractor has begun starting very hard. have to crank for maybe 20 seconds or more. wait a few seconds and crank it some more and keep choking and shut the choke off and choke some more and if I get lucky it will fire up. if not I wait till next day and try again and hope I get it to start. once it starts it runs fine with no issues. has new plugs,air filter,gas filter. any suggestions???? thanks in advance
If that's the same set up as one I worked on a while back you will have a screw in the bottom of the carb on the side. It's a drain valve. Empty the carb and check for water in the carb.
How many hours on it.Week coil would cause hard start,do you have a good spark.The valve lash should be adjusted every 800 hours,this would cause hard starting also.
