Walk behind 33" cub cadet walk behind 10.5 hp
jordanbryan
I have a 33" cub cadet walk behind with the 10.5 hp engine. Wondering if I could attach a valke and some weights on front to stabilize it. Would it still perform well?
I wouldn't even try it. Those mowers are so light it probably wouldn't be able to handle the strain
I think it depends on how much you weigh :/ I weigh 140 I would try it. Weights to stabilize are not a good idea as you are not affecting the balance of the machine (if you install the velke right) and if you don't ask to much of the machine steep hills and sideways on hills are probably a no go.
