Mwh0428 Well-Known Member Joined Dec 19, 2011 Messages 164 Aug 27, 2013 #1 On my john deere 317 it vibrates badly it does not do it with little to no load on the hydraulic system and trans. Regardless if the deck is turned on or off Sent from my droid 4 using LMF
Mwh0428 Well-Known Member Joined Dec 19, 2011 Messages 164 Aug 27, 2013 #2 All most forgot the model numbers Kohler magnum 18 Model m18 Spec 24541 Serial 2012205916 317 tractor C317L 200278 m Sent from my droid 4 using LMF
Mwh0428 Well-Known Member Joined Dec 19, 2011 Messages 164 Sep 6, 2013 #3 Well with no reply I am going to just assume its u joints any other ideas? Sent from my droid 4 using LMF
BBO Well-Known Member Joined Jun 9, 2013 Messages 126 Sep 6, 2013 #4 Mwh0428 said: Well with no reply I am going to just assume its u joints any other ideas? Click to expand... Does it sound like the engine is firing correctly? "Vibration" is a word subject to lots of interpretation...
