Just bought a new house with a 3 acre yard. The house sits up on a hill and the yard gently slopes down to the road. Definitely not a high grade for cross mowing. Just gently sloping. I need some help on buying a mower though. I've read through all the various threads and been to all my local dealers. Each says that theirs is the best. I'm sure you know the story. The problem I'm running into is that I can't seem to find what I think I want for $7K.
Here are some of my preferences:
Koehler or Kawasaki engine with canister filter preferably
54" minimum deck
They dealers are all telling me I should go with a mower than uses "pump and wheel motors" as opposed to "transaxles", whatever that means. They also say I need grease able spindles. Is there any truth to either of these?
Really like the Grasshopper 223, but it's out of my budget. Liked the Hustler Fast Track Super Duty, but it has sealed spindles, transaxles, and felt like it sat really low to the ground. Like the Bad Boy CZT, but when I climbed on them, the seats all felt weak and they squeaked badly. Just didn't give me a good feeling of quality. And the CZT uses transaxles too. LOVE the Ferris 2000z, but they are way outside my budget. No Dixie or ExMark dealer within reasonable driving distance. Didn't care for the Scags in my price range either.
Is there something I'm missing or am I being too picky for my particular needs?
Maybe a use ag tractor with a 6 foot bushog and then a finish mower for around the house
The dealers that are recommending pumps and wheel motors and greaseable deck spindles are giving you information based on their service experience and this is good info.
There are some good machines that have Hydro Gear hydrostatic drive units and I suggest that you do some research on these drive units to be better informed about them when you make a decision on a machine. Hydro Gear has a nice website and some info about their products.
The few folk that I have chatted with that have purchased BadBoyz machines have not been happy with them.
Some basic guidelines that I recommend:
If you are not capable of servicing the machine yourself, then think about a machine from a local quality servicing dealer.
Larger diameter rear wheels are better for ride quality and minimal turf damage while turning around.
A foot operated deck lift for quick raising of the deck to get over obstacles that can cause blade damage.
A canister type air filter on the engine.
A sizable fuel tank(s) so you don't need to refuel as often.
A comfortable seat and control position.
More HP is better than not enough particularly with collection systems installed.
Possibility of collection system, some machines are better setup to accomodate collection systems.
Just some of my thoughts!!
You can go with the pump and wheel motors but you really don't need those, there more for a commercial application, and grease able spindles IMO are a must .Any mower with the 2800 or larger Dual Hydro-Gear Transmissions are more than enough for a three acre yard. Have you checked out the Cub Cadet Z- Force, you can buy the 54" for $4799
Cub Cadet - Zero Turn Riding Mowers - Z-Force Riders
I run the 44 and 48" in the business and I can tell you for the money you can't beat the mower
Anyone know what I could expect to pay for the Cub Cadet Tank LZ or SZ? Those seem to be the two Cub models that have the features that I want. I have a feeling they will be out of my budget though. But still interested in them.
$7K isn't bad depending on the motor. I went by my local Cub dealer today, but they didn't have a single Tank model. Bummer.
Thanks Ric. Both are engines that I like, with maybe the Koehler by a little more. Do both models come with the cannister-style air filter?
I'm in a similar situation. I am going to begin mowing 3 acres for my church that has some pretty steep slopes and will probably not be the smoothest ground. I've read the horror stories of a ZTR on slopes and I wonder if time savings will be worth the risk of an accident. I'm thinking about a JD x500 with a 54" deck. Is this a good decision?
54" minimum deck
you would need a large zero turn for 3 acres...I would opt for a tractor with a finish mower on rear and use a rider or small zero turn around the house.
Someplace, some where I saw a new product. It was like a cross between a lawn tractor, a generator and a mini-vehicle, (like a very small ATV.)
It got me thinking. Why not? Why are there no cross bred ATV's and Lawn Tractors? The unit having an onboard generator doesn't do much for me but I have to say- I love that someone is reinventing the concept. In a perfect world, I'd like to see a tractor with HIGH clearance, 4x4, removable (finish) cutting deck, rear platform that would accept ATV tools, (broadcast sprayer...) and a rugged trailer hitch so I could remove the finish deck a pull a 54-60 inch rough cut mower so I could do the fields...
I may be insane but I'd like to see the product.
Based on my problems mowing 2 acres with an Intek 24 powered craftsman 3 bagger stay away from Briggs. Got a lemon? Maybe I did. Without any reason other than proven engine tech in motorcycles I'd go Kawasaki. Bad vibes on this forum for current Kohlers? And consumers mag is not recommending Cub Cadet due to problems ( buyer surveys). Also notice a big ad campaign by Cub Cadet. Should that scare us?
