Put a shut off valve in the fuel line, the carb needle valve likes to leak a bit and it will flood the engine and in some cases fill the motor full of gas. And if you by chance pull the plug out to purge gas out the cylinder make sure you have the spark disabled or you WILL have a fire. You will need to drain the oil too.
