?27 hp kaw runs well for seconds or minutes, then cuts out: help!
monkfarm
  • / ?27 hp kaw runs well for seconds or minutes, then cuts out: help!
:confused2: 27 hp kaw in 02 Scag Cougar both with 659 hours. Have replaced fuel filter, fuel pump, disconnected safety cutouts, and oil alert shutoff. Now seems to run well for 20 -30 seconds and then :confused2:cutout. I'm going to go out and blow out the fuel lines, have not done this yet.
gregjo1948
Check fuel tank cap vent. gregjo1948
Kent County Lawnmower
You say cuts out doesn't stall altogether I just lose power?
monkfarm
Sorry, I was out of town, I came back, installed a new fuel pump, drained the old gas, put in fresh, and it's still cutting out. Most of the time it has plenty of power, but 1/3 of the time it starts up, it has very little power, and requires the choke to keep it running. . . Hope you are still looking at this, Kent county, I guess I am just grabbing anything to try. . .
monkfarm
Could the problem be a bad ignition coil, and how would I check for this. . . It runs most of the time.
monkfarm
Scag Cougar 27 hp kaw: Could the problem be a bad ignition coil? 659 hours. garaged. Runs for seconds or minutes then falters.
Fish
drain the water and crud out of your carb!!!
monkfarm
I drained the gas tank, and put fresh gas, (it started and ran for a little while after that, so it probably cleaned out whatever was in there, right?) cleaned the air filter, used Amsoil power foam on the carb.
gregjo1948
Maybe you have a faulty fuel solenoid. gregjo1948
monkfarm
It ran for awhile with a new carb., now it is cutting out, I start it right up and it cuts out. I don't think it has a fuel cutout solenoid, I am looking at the scag Kawasaki electrical schematic and I don't see anything like that. . . Someone tell me different, but tell me where it is, because it is not on the schematic.
