I recenlty bought an crafstman tractor with a 26 hp Oil leaks from the shaft seal even when the tractor is NOT running. Previous owner had shaft seal replaced, but oil leak remains. I ordered a new shaft seal since they are cheap, but I have some questions...Is the shaft submerged in oil or is the head gasket leaking internally??
