- Sep 24, 2017
- 284
- 6,847
I don't guess a worn cam lobe could cause this, could it?
That would probably be more constant.
Just now got through mowing for about an hour with this machine. When riding on it, and mowing at higher rpm, you don't notice any problem. It starts instantly, and idles smoothly. But, when it is sitting still, and you get behind it, while increasing rpms, it starts with frequent hic up, and even a subtle back fire now and then. After having checked the valve clearances, compression, and putting in new plugs, I was wondering if these symptoms might indicate too high a fuel level in the float bowl. Thanks for suggestons.
If you would have stopped at a gas station back in the days In a volts wagon and filled it up with gas. Then going down the interstate and got behind a semi truck and followed it for several miles I would almost bet your engine would over heat and blow up and your gas tank would almost be still full of fuel. ... .
Sounds more like a lean condition to me, I would try spraying WD40 or carb cleaner around manifold to block/ carb to manifold gasket areas to see if it makes a difference in rpm indicating a leak. Also makes me wonder about head gasket.
Walt Conner
to set the record straight. Going to a race in Atlanta back in the 70's, in Texas, and pulling a small camping trailer into a very strong 50 mph head wind in a 1971 VW bus we could not get over 40 mph. We found a semi that could not get over 40 mph either and he had no problem with us sitting 4' off the back of his truck for about 2 hours since both of us were able to speed up to about 60 that way. He used his turn signals to tell us what was going on at a distance ahead. With a full set of gauges on the bus - oil pressure, oil temp, cyl head temp etc., I can assure you that we actually ran cooler because their was less effort pushing into the headwind. Air cooled engines need air volume to cool, and the best benefit comes at a spot where the fan is most efficient. A heavy load at low RPM is hardest on air cooled engines.
As to the OP - probably changing the air filter, and fuel filter would be where I would go with this. That said, I have seen this behavior in some of my air cooled engines around the landscape and garden. In each case it turned out to be a worn out fuel pump (diaphragm) or loose carb jet. Modern fuels attack many of the fuel diaphragms and this causes an inconsistent supply of fuel - which in turn causes the surging.
Ok Walt, will try spraying some WD around the intake. I remember having a friend that did that to my 250 Honda that was fussy. One cylinder did have a little oil coverage around the head, which had happen over time. It wasn't fresh. The other cylinder was dry. I forget which cylinder had the highest compression, but they showed 150 and 160. If it were a head gasket, wouldn't the compression be much lower? I mowed again with it tonight. When I am mowing at higher revs, you hardly notice it. And, at idle, it sounds fine. But at about 1/4th throttle, it starts to spit, and sort of has a lope to it. I really hate it, because it was so perfect before last week. I will check the compression again. I will try the WD and check the compression again.
Head gasket starting to leak will not show drastic compression loss. Just trying to think of something which might result from getting hot under load. Long shot, might run some SeaFoam thru it per instructions on container.
Walt Conner
Was mowing tall grass on a 90 degree day, with throttle nearly open, and afterwards noticed that this 26 hp intek started belching frequently. It doesn't exactly sound like a back fire, but on that order. It starts and mows fine, and when running at slow speeds, or idle, it is not as noticeable. I had just been bragging about this engine, which has over 1000 hours on it. It has been well maintained, uses no oil, and has always run perfectly. I will do some checking tomorrow, but wondered if others had experience this.
