Thanks, I’ll look again at the parts manual.Yep , that is a belt retaining spring it is supposed to be pointing upward not down
It is designed to stop belt from jumping off the 90 degree pulley between PTO and 90 degree pulley
Get a parts manual and it will show you where it should be positioned
Doesn’t really show where it attaches. Is it supposed to attach to a spring?Thanks, I’ll look again at the parts manual.
Yes, but does it attach to that spring, part #11?That is a belt guide. In this manual go to page 16, part number 10. Should be mounted close enough to the pulley that so the belt will not not jump odd the pulley when the tension is released. https://apps.mtdproducts.com/manuals/769-04806.pdf
