johnwayne377
- Sep 28, 2011
- 3
- 5
My 25 hp command kohler has set through the summer because no rain means no mowing! I always winterize it and havent had one bit of trouble with it, but i parked it in may and just now got it back out. I had trouble gettin it started but finally stopped and drained the gas and cleaned the plugs. It would the finally crank but just barely run. After four times of dissasembling the carburator and cleaning it runs so so but only with full choke. Sometimes it runs perfect then rough and i can remove left spark wire and no change, so i am thinking i have spark trouble. Any help will be appreciated
