scarface998
- Mar 17, 2019
- 2
- 9
Hello everyone, I have a 24 horsepower double cylinder briggs on my mower. Its an OHV horizontal engine. I have been having an issue with it since i bought it from the owner and i'm not sure if maybe its just a carb problem or if there is something different going on. No matter what i do, the engine will not start without some kind of starting fluid to start combustion. After it fires, it starts pulling in gas on its own just fine. The guy i bought it from said he changed a wire but i cant remember what wire he said he changed. There's a little wiring box that's open and spliced on the side of the engine. Ive checked the fuel pump and its working, I've checked the air intake and its working fine, and once the engine is running, it runs flawless. All spark plugs and coils are working fine. It's just getting annoying to have to use starter fluid every time i want to start the engine. Any ideas why it wont pull fuel from the carb until the engine starts? Maybe a vacuum leak? Does this carb even use vacuum? Thanks for any help!
