Engine 24 hp b&s vtech moter.
oldghy
Hi. Just signed up to the Forum. This is what I have done so far new fuel filter new spark plug gov adj checked ele clutch
replaced mower belt cleen carb blew air threw fuel line engine starts a lot better seems to have mower pwr and smoother Still was not going up a gradual rise put some fuel additive to off set ethanol started getting power back.
Next time I got it out would not go up hill with blades running and moter dosn,t seem to slow down when placing lever to slow when warmed up, motor starts to slow down a little slowy thinking fuel pump next as mower got a little better
when I blew out line from filter back to tank last year. But fuel looks good in filter I put air fwd threw fuel pump maybe harmed fuel pump but why would it work fine for a while than act up again ?
Sorry about the length of post. I can mow the lawn across the grade but the smallest incline it dies out but dose not stop but it really struggles. Thank you for any suggestions.
:confused2:
mechanic mark
Post tractor model number from under seat as well as all numbers from engine, example: model xxxxxx, type xxxx, trim or code xx. Thanks
Object moved click anyway
Manual Craftsman Lawn tractor 917273621 | SearsPartsDirect Download troubleshooting section in manual for symptoms. Check air filter for replacement as well as transaxle drive belt.
Craftsman Multi-meters from Sears.com Purchase an inexpensive multimeter and check fuel shutoff solenoid for operation. Hands on, check all wiring and connections for being tight & secure. Wiring diagram is in manual.
oldghy
Tractor Model No. 917.273621 Engine Model No.445777 Type No.0168-E1 Code 040420YG.
Fish
Sounds like a layer of water and crap in your carb bowl...
oldghy
I have a manual and I will retrace my trouble shooting. Thank You!
