B Big- ed Forum Newbie Sep 27, 2015 #11 before getting into that crankcase and doing a whole lot of work pull the carb and see if the throttle plate is still there
T Tinkerer200 Well-Known Member Sep 27, 2015 #12 Big- ed said: before getting into that crankcase and doing a whole lot of work pull the carb and see if the throttle plate is still there Click to expand... Already suggested checking that several posts back with the following response. "Thanks for the info, with the engine running I was able to control the engine speed by manually moving the governor arm." Walt Conner
