23 hp cv23s kohler command cranks but no spark
pittfan
my mower quit running, and after awhile it would fire up and run again. But now Im not getting any spark at all.
wants i replaced the coils it fired up for about 15 seconds and quit.
How about supplying us with the full model and spec number from the engine plate so we can see which of the 4 ignition systems you have.
pittfan
the spec no. is 75613 serial no. is 3600310631
I was looking at it last night and disconnected the two kill wires
, tried it and it fired up. not sure whats causing this.
EngineMan
You may have a bad wire on the kill side going to ground, or something wrong on the key switch or a bad safety switches, this maybe just a start..!
pittfan
thank you, I'll look and see what I can find.
pittfan
I think I found it. the switch under the joy stick is bad. Thanks again for your help.
EngineMan
Good to know you find it, thanks fr the feedback.
