22 hp Twin Cylinder Sputters
Chuck Tyler
My John Deere E140 has a 22 hp Twin B&S that had to be serviced (under warranty) because the starter gear jammed and ruined the flywheel. I took it to the Deere dealership and they replaced everything, but ever since then, the motor sputters while it's running. Does it sound like something I can fix? I'm old and loading that thing up and taking it to the dealer is a pain. It only has 67 hours on it. Thanks for any help.
To Be Honest i'd take it to the dealer and let them do it, i would imagine they should either fix something they did wrong or it may be covered under the warranty.
if you try to fix it and mess with something, it may void your warranty.
Thanks for the reply. I guess that's what I'll do. I was just hoping it was just a simple adjustment, but your point about voiding the warranty is well taken.
