scalestick
- May 30, 2012
- 12
Wondering if anyone can tell me what Models of Honda Mower HRM 215 are fitted with Spicer Transmissions The model # is missing all I have is the HRM 215.
The "K3" version of the HRB/HRB215 mowers used a Dana/Spicer transmission. It does not have any internally serviceable parts.
What problems are you having?
When in second gear it skips if I lift the back end the wheel are ok, seems that the shifting arm is not keep the shifter in place . At present I have the transmission apart all is ok inside except the shifter arm is loose even after I tighten the lock nut. For some reason the Honda Garage tell me it is Hydrostatic, it was full off gear grease when I cleaned the unit up
Thanks for you time .
Scalestick
If your shifter has a 1-2 (2-speed) lever, for sure you have a gear-type transmission, NOT a hydrostatic. If you've eliminated all the external issues, and still having trouble with it holding second, it may just be the trans. is worn excessively, and might need replacement. Process of elimination...you might get lucky and find a used one or old matching mower with a shot engine but good transmission. Worst case would be to replace with new, it does come with a warranty. Not cheap, but cheaper than a new mower.
The worn rectangular hole on the clutch shaft lever seems to be a weak point on these transaxles that causes either erratic or no clutch engagement. I have this very same issue, and came across a youtube video of a guy who also had this problem. I haven't looked it up yet, but are the levers available as separate replacement parts?
Finally received the parts both clutch and shift arm installed new parts replaced the transmission all is working. Scalestick:
