I put the new coil on and its running on both cylinders now. The right cylinder smoked like crazy burning off a bunch of oil build up so it looks like the previous owner had been running it like that for a while. It has plenty of power to mow now.
Bert, I noticed after cranking it for a while it actually dripped gas from the bottom of the left cylinder head which has the lower compression. I'm new to small engine repair but I don't think its supposed to do that
I think you're right, I need to pull and inspect that head.
