20340 Toro Recycler hard to pull back
Bobz1
Sometimes is has to be dreaaked back, rear wheels tounig but very stiff and other time ir rolls back freely.Its only 4 yeats old and does not get heavy use. Any suggestions?
Remove all the wheels. CLEAN everything you see. Compressed air, solvent tank or leaf blower. Take an oily red shop rag and wipe it all down. Then another clean DRY rag and do the same. Reassemble and test. Easy right?
Don't oil or grease anything you see unless your manual states so. Mainly will attract dirt and grit wearing parts out faster.
Then remove the top engine cover and clean the block and fins like a NEW ENGINE.
sgkent
and replace the drive belt when you rebuild the wheel assemblies.
This problem is not a wheel problem!!!
