2026 Toro 60" Havoc Timesaver
I've seen a broken spindle, or bent deck, cause the blade tips to collide and make a banging noise. Check the tip of the blades compared to each other. All should be level and at same height. One may be bent. Compare the heights and levelness of the spindle pulleys.
