JayT50
- Sep 20, 2023
- 3
I just bought a 2021 MZ Magnum 54 from FB marketplace. I noticed when I first started the mower it had a delay, a drag, and after one or two drags, the mower turned over and started. The guy said he had just replaced the battery and based on the sticker date, that was true. I used the mower 2-3 times, same issue, slow to turn over, almost like the battery was weak. Yesterday I finished mowing, and I blew off the dust from the deck before returning it to the garage. When I turned the key, no start, a click or two, a really slow crank, and nothing. I looked at the cables to the battery to see if they were tight and I noticed both positive and negative cable ends were really hot. I tried to arc the solenoid, and turned over some, better than it had, but would not start. I also. noticed the ignition key is stuck inside the ignition. I looked for burnt or bare wires, loose wires, etc and didn't find anything. I was going to replaces battery cables, solenoid and the ignition switch. Any other possible reasons for slow to no crank and hot battery cables? Thanks
