2021 54" Magnum hour/tach not working
ken2
Was putting all my mowers away for winter. I noticed the hour/tach meter on my 2021 Magnum was not working. It doesn't have any display on it. Is there something I should be checking wiring wise or does the meter need replaced? It had around 60 hrs. It was working last time I used it which was mid Oct.
Most hour meters used on mowers are internal battery power model with no external power source. The batteries will run down just depends how old the meter itself is.
