2020 Snapper RER died suddenly
Richard Milhous
Or a piece of vacuum hose from a car. I've made more than one repair by chopping off a bit of vacuum hose from a run that had slack in it, or connected to some emission stuff that I really didn't care about.
Right, use something to bundle and protect the wires. Use grandma's yarn if you have to.
hlw49
While U had the carb off did U check the fuel shut off solenoid. Turn the key on and listen for the solenoid to click. If not U can test it just plug it in with it screwed out of carb. turn the key on to see if the plunger retracts. If not most of the time U can clean it with carb cleaner. Spray it and work the plunger until it operates freely.
hlw49
Yes, switch is good.
When you get off the seat, that switch should be a short or close to 0 Ohms. That switch shorts the ignition coil out and prevents spark. When you sit down on the seat, switch should read OPEN.
Not all the time some seat switches activate a relay and in that case could read right the opposite. Which would kill the engine.
