2018 2025 JD 30 hours. Roll Backed back to dealer 5 times. JUNK!
Mark Plummer
Yep, 32 hours. over 20G. Garage kept and only used to mow. They towed it 5 times for repairs ( Transmission became loud and shavings were found in a valve and a filter was clogged.) 2( Lifted 60D mower deck in driveway when a loud explosion like a shotgun. Parts shot out from under tractor and deck slammed to the ground. Bent all the aluminum linkage arms to deck last week and no parts. Grass getting high. Dealer says no loaner. After getting tractor returned from the shavings in the transmission deal and after I had mowed several times, I noticed the transmission drain plug still had all the paint and was never removed. So I was using my new 2025 John Deere with contaminated fluid. This time dealer sent a mobile service trailer here to change both trans fluid and filter.) 4 First time I used the loader was to take weights from my weight bench from garage down to basement apartment. Got half way down drive and used the brakes for the first time. Loud screech but no brakes. Dealer wanted to know Y I even use the brakes). 5 ( Could not get the QUICK CONNECT deck connected without a floor jack and friends. The mower deck height control was broken so I could not adjust height for mowing or to remove and replace deck.) 6 ( Oh almost forgot. The differential locked up while mowing). That's 5 trips back to John Deere on a Roll Back and one service van brought to my home to replace the contaminated fluids in the transmission. WOW! Called JD 4 times before a case file was even opened. Josh talked to me twice and later stated he never started a case file because he didn't think I wanted any help. HUH? Then finally was called and was told to enjoy my new JD. I want another tractor. Started a law suit so now they wont talk to me at all. They have my $ and my tractor. Please forward to anyone and everyone. ( 32 HOURS ON NEW 2025R )
