Got this thing about a year ago 90 hours on it.  Price was good, figured how could I go wrong?  Little did I know, what a frustrating piece of equipment it would be.
And it is a great mower, but the worst at starting of anything I've ever owned! And I really mean cranking - if it'll crank, it'll start.
It has pretty much always cranked when cold/not been run.
But after than, all bets are off. Anytime you've used it for any length of time, it simply may not crank if you go to start it again. Or it will - can't really seem to find a rhyme or reason.
Anyway, finally a month ago, mower wouldn't crank at all.
So, I replaced the solenoid and it worked flawlessly for about a month - would crank anytime I cared to try it.
But since then, it has returned to it's old ways - starts cold and maybe not any other time.
I do have another solenoid, but am starting to doubt that is the real problem.
Why would a new solenoid only work perfectly for a month?
And yes I've figured out Plan B for starting - plastic handled screwdriver across the solenoid terminals. But I'd rather not have to rely on this method of getting the thing to crank, when it won't otherwise.
So anyway, any clues as to what my really problem is here?
The solenoid is easy to change, but I'd really like it to stay fixed this time.
Thanks.
Thanks.
