2015 Troybilt Pony red wire broke from 20 amp fuse
83Indian
The red wire coming from the 20 amp fuse in the back broke. Where does this go? I have tried connecting to solenoid main positive line to battery but that blew the fuse. As is the mower won’t start, I have replaced the solenoid and ignition switch. I confirmed the brake cutoff switch is engaged. Mower is in neutral, mower deck up, mower deck is not engaged. I can jump from battery to starter and engine cranks but no start. Model# 13WM77KS011
Yep that’s what I tried connecting to the solenoid. I can try the other terminal on the solenoid and see if that works.
Well connecting to the solenoid was correct. Not sure what I did wrong the first time but it works now.
