I have downloaded the repair manual that Mike linked to. I printed pages 57-59 pertaining to changing the drive belts. I actually have 2 new belts ($60!) as I read the owners manual that I downloaded, and it said to change both drive belts at the same time. The original order track said the belts would take 10 days to arrive. As I waited for the belts, I grew impatient and bough the top belt only from Lowe's, another $32!.
The repair manual says the belts should last for years. As the top belt failed after only 6 months, I have a couple questions. How important is changing both belts?
What could have caused the failure in the first place? The steel core of the failed belt was broken and pulled out for about 1/3 of the belt circumference. the belt appears to have had half its width chewed off.
Last question. The bracket that the idler is on is shown in the manual as having a slot where the pivot bolt is. Does this mean it should be adjusted? Or does this bracket slide in operation? There is no procedure for it that I can find in the repair manual.
The repair manual is dated 2010, so this series machine has been around a while. Someone here must have seen this failure before, and understand what caused it.
Just for giggles, I took a picture of the damaged belt next to a new belt, and added a picture of the idler bracket.
Chuck
