2014 Craftsman T3000 Ground Drive Belt Diagram?
tsvoma
Just got this mower and I'm looking to see if prev owner put the belt on wrong because it doesn't make very nice sounds when I let off the brake. You can see in the pictures the diagram on the tractor doesn't show the correct way instead says possible other config :/ Just looking to see if anyone notices anything funny or if its on right/wrong. Model # 917203900
Thanks in advance!
dawgn86
same model for me and my belt is routed same way. Mine made a bad screeching noise when I let off the brake and it was the first pulley going bad.I couldn't get it off so I took the rubber bearing guide and used a needle point on the end of my grease gun and pumped in several shots of grease. Solved my problem at least for now.
