NJK570
- Aug 27, 2020
- 1
I have a 2013 Ferris is700z zero turn with the 28hp B&S Turf engine on it. I have had a slow leak for a couple weeks now but it's seem to be getting worse. The left hydraulic reservoir is almost empty which tells me the fluid leaking is hydraulic fluid. The weird thing Is that the leak seems to coming from below the B&S engine and not the hydo Motors on the wheels, they're dry as a whistle and so are the lines. How can I be leaking hydraulic fluid from the bottom of the engine? I can't even see where the leak is coming from because of all the metal shrouds but I know for s fact it's coming from where the engine sits on the frame.
