When I mowed today my Cub Cadet Z-force-S 48 would zero turn to the left OK but when turning right, a 10 to 15 foot radius was as close as it would turn and going straight on level ground the steering wheel was turned maybe 15 degrees to the left. It had zero turned both ways one month and 7 operating hours ago when I bought it used, and while I had noticed some increase in right turn radius my previous mowing time, it was much worse today so it appears to be a progressive thing. It also had some trouble getting started up a 20 degree slope today if the front wheels were turned at all and it felt more like a belt was slipping than the wheels slipping.
This is a 2012 Z-force-S 48 model with a mulching kit installed and 175 hours on it. Half of the acre of property I mow is sloped 15 to 20 degrees and half of the rest is pretty rocky and bumpy. I weigh 160 pounds and am running 8 PSI in the rear tires to soften the ride on my rocky Arkansas hillside. I usually mow across slope on the steep part and zero turn downhill on succeeding passes because there is not enough traction (or maybe not enough drive belt friction?) to zero turn uphill which I assumed was because only one rear tire was driving forward on a zero turn.
Do you guys have any suggestions on where to start with correcting the steering situation? Or the drive belt adjustment? I found a Z-force service/repair manual on line but it is for the L model and not the S; another case of Murphy’s Law that “the repairman will not have seen a model quite like yours”.
Also, this unit may have been sold with the mulch kit already installed by the dealer and while it does a really nice job on the grass and leaves no clumps or even any visible clippings, even a slight bare spot creates a whole lot of dust and it builds up a ton of dry clippings covering the mowing deck in an hour’s time that takes almost as much time to clean it off as it took to mow. I am considering removing the blocking plate on the right side and am wondering if it will then discharge without causing a dust storm or if I would need different blades for side discharge. The blades are marked 02005017 on one end and MB 0 2D on the other.
Edit 1: I found a service manual at
http://service.mtdproducts.com/Training_Education/769_05513_z_force_s/769-05513.htm Whoope! I can still use advice before pull the deck again and dig into the steering, but at least I have a place to start and some photos to go by.
Edit 2: When I added edit 1 it blew away my original post, but fortunately I had it saved in my notes on the Cub so I put it back ( at least I hope I did)
