2011 Ariens 42" Lawn Tractor 19hp Kohler Engine 2 Issues
LT1045wrh
  • / 2011 Ariens 42" Lawn Tractor 19hp Kohler Engine 2 Issues
Hi,
I was doing an adjustment on the valves and when I was tightening the valve cover to the engine housing, I over tightened the lower right bolt and broke one of the tabs that holds the valve cover to the housing. Is there a way I can just tighten the rest of the bolts and be okay? Or, is this going to cost me major bucks to get a new engine? I'm a real :confused2: for doing this. I'm always so careful, but I guess it can happen to anybody. :ashamed:
I've also had another problem with this mower, I can't seem to get the starter to turn over, despite new battery and new solenoid. I jumped the old solenoid with a wire and the starter engaged, so I thought I need a solenoid. I still can't get the thing to turn over.
W
A good TIG welder might be able to weld the tab back on. Kohler does not recommend using a liquid gasket sealer on the valve cover, but that also might be worth a try.
This troubleshooting procedure might help to pinpoint the starting problem, if it is not a mechanical problem.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). *If you have power what is the voltage?
Fifth, check for power at the starter while holding the key in the start position (assistant again). *If you have power what is the voltage?
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
LT1045wrh
Thank you for the detailed instructions. When I am able to have a day to work on this again, I will update to let you know how it went.
Have a great day,
W
