2010 MZ deck won’t stay raised
Univity
The deck seems to be stuck at the lowest setting … when I push in the pedal it raises, but when i put the pin in… it the deck goes back to the ground … I also notice that the left side of the mower barely raises (opposite side of where the raise pedal and adjustment holes/pin go) … Any ideas ?
May be a good time to look under the mower and see if the deck hangars came loose from the deck and also look for anything else out of place.
Univity
To follow up… after further inspection the rod that goes under the mower became detached from the bracket … required some welding to fix but I was able to do that myself easily
Thank you for the update and for giving us the repair.
