trunkbuster
- Jan 1, 2015
- 1
I'm having the same trouble with my 31 series engine, it won't crank past compression. I've adjusted the valves to the recommended clearance while the piston was at 1/4 past TDC and also at TDC so I believe it's the compression release. The battery is good, I've tried two. It spins over just fine with the plug out and the oil level is ok. There is no gas in the oil. I couldn't find any posts on how to correct this problem. Does anyone have any experience correcting this issue?
